8 years agoCompiling with different seeds and Aggresive optimizations
My compilation failed due to complex routing. !=========================================================================== ! The report below may be inaccurate. A more comprehensive ...
8 years agoThose messages are for people who use Quartus directly. You can change the seed using the --seed switch followed by an integer number but considering the high logic usage and the high possibility of overutilizing the Block RAMs, you will likely not be able to successfully compile this design unless you somehow reduce the area utilization.
