KenCiszewski's avatar
KenCiszewski
2 years ago
Compiling VHLD file in quartus
I have been learning about quartus using
https://www.allaboutcircuits.com/projects/from-vhdl-code-to-real-hardware-designing-a-finite-state-machine/.
There's a VHDL file that I compiled in quartus for the EPM240 FPGA see attached. For a while it compiled correctly, eventually I got all kinds of error messages.
I compiled as Verilog HDL and VHDL, for a while it was fine as Verilog HDL, but eventually wouldn't compile.
Any thoughts?
  • FvM's avatar
    FvM
    forgot to tell the error messages.
    • FvM's avatar
      FvM
      The original VHDL file compiles without problems in Quartus 13.1. It should be however noted, that the default "one-hot" state encoding leads to a very inefficient counter implementation in 27 logic elements. Specifying sequential encoding, e.g. using synthesis attribute reduces resource utilization to 6 LE.
  • ShengN_altera's avatar
    ShengN_altera
    The file had been compiled in VHDL without any problem as mentioned.
