osmanyagci
4 years agoCompiling the s10_ref (20.2) on Quartus Prime Software Pro
When I try to compile the s10_ref project (Version 20.2, Downloaded from Intel Download Center), Quartus compilation ends with errors. What migth be the reason for these errors? I did not make...
- 4 years ago
Applying the steps mentioned in "Intel® FPGA SDK for OpenCL™ Pro Edition: Getting Started Guide" solved my problem.
skyjuice
4 years agoDo you mean this design is downloaded from Intel Design Store?
Can you try to compile this design in the same Quartus version the design is developed in (i.e 20.2)?
osmanyagci
4 years agoYes, downloaded from intel download center.
Is there a way to upgrade it to 20.4 so that I can run it on quartus 20.4. As I can understand from the related documents intel does not support bsp files above version 20.2. I could not find how to upgrade this file to 20.4.
