Compiling the s10_ref (20.2) on Quartus Prime Software Pro
- 4 years ago
Applying the steps mentioned in "Intel® FPGA SDK for OpenCL™ Pro Edition: Getting Started Guide" solved my problem.
Do you mean this design is downloaded from Intel Design Store?
Can you try to compile this design in the same Quartus version the design is developed in (i.e 20.2)?
- osmanyagci4 years ago
Yes, downloaded from intel download center.
Is there a way to upgrade it to 20.4 so that I can run it on quartus 20.4. As I can understand from the related documents intel does not support bsp files above version 20.2. I could not find how to this file to 20.4.
Is there a way to upgrade it to 20.4 so that I can run it on quartus 20.4. As I can understand from the related documents intel does not support bsp files above version 20.2. I could not find how to upgrade this file to 20.4.
Hello skyjuice,
I have also tried to build s10_ref (20.2) in intel quartus 20.2, but it again gives exactly the same errors as in intel quartus 20.4 built. Can anybody help me on these issues?
Note: I have done the necessary steps mentioned in the document named "Intel® FPGA SDK for OpenCL™ Pro Edition: Getting Started Guide".
Thanks in advance..
