8 years agoCompile error with alteracl.lib using mingw-w64 on Windows 10
Hello! I am trying to compile an open-source project with the Intel OpenCL FPGA SDK 17.0 and an Arria 10 board on Windows 10 using mingw-w64. I got an error when the makefile run a command looks like...
8 years ago --- Quote Start --- hi, If you do not want to purchase a costly VS2010, do consider to use the centos 6.8/6.9 as Gcc compiler do not need additional license. There is a plan to make vs2015 in the windows support list in the future but now still only with vs2010. Regards, CloseCL (This message was posted on behalf of Intel Corporation) --- Quote End --- Thank you for your advice! Is the OpenCL SDK for FPGA supported on centos 6.8? I thought it's supported on Redhat.
