8 years agoCompile error whilel using Quartus Prime
I am getting the following compile errors while compiling a project in quartus prime, as follows: Error (275029): Incorrect connector style at port "dataa[7..0]" for symbol "inst" of type mult ...
8 years ago --- Quote Start --- You still have multiple shorts. Delete all the wires until you don't see any crosses or rounds and reconnect everything. --- Quote End --- Thank you Daixiewen. I tried doing that but a round still appears. I used a diagonal bus line to go from the first data(0..7) of mult to input vcc by clicking on one end and dragging till it meets the other end. A dot then appears. How do I get rid of it or draw so that it doesnt appear? Thanks in advance!
