8 years agoCompile error whilel using Quartus Prime
I am getting the following compile errors while compiling a project in quartus prime, as follows: Error (275029): Incorrect connector style at port "dataa[7..0]" for symbol "inst" of type mult ...
8 years agoHi,
You can take a look at the attached project, I've created a almost identical design setup and have got it to compile successfully. The device used is different , while the LPM blocks used are almost the same with minor variations. You can use this as a reference.
