8 years agoCompile Error of vector_add in de5a_net_e1 board
Hi, When I was running "aoc device/vector_add.cl -o bin/vector_add.aocx --board de5a_net_e1 --report" I got this error message: "Error: Compile Error, no able to genertae hardware" And i...
8 years agoYou MUST use the same Quartus and AOC version. The v16.0 BSP should work with all versions of AOC from 16.0.0 to 16.0.2. If your machine only has 4 GB of memory, you are not going to be able to successfully compile anything on it. Depending on design size, between 18 to 48 GB of memory is required for successful compilation on Arria 10. The compilation log does not clearly say why the process is failing; I would assume you are running out of memory.
