10 years agoCompile can’t geneate file .sof in quartus 13.0
Hi all, I have been running an example " Triple-rate SDI II Reference Design for Stratix V, Arria V & Cyclone V devices", using Cyclone V GT Development kit. , Link reference on alterawiki. Bu...
10 years agoHaving unlicensed IP in your design can cause Quartus to not generate any programming files. Do have any IP cores, like Ethernet, in your design? If that's what's going on you should be able to get a demo license for the core. In that case the .sof file will be generated but will be time-limited (will only run for a fixed period of time, usually a few hours).
