10 years agocompile and run issues of Hello world
Hello, I downloaded Quartus Prime Standard Edition 16.0 for Linux, and the Hello world from https://www.altera.com/support/support-resources/design-examples/design-software/opencl/hello-world.h...
10 years agoHi Hongbo,
Check out the Getting Started Guide for instructions on how to get up and running with the emulator flow. Have you set the CL_CONTEXT_EMULATOR_DEVICE_ALTERA environment variable? I believe you will need that in order to emulate an OpenCL FPGA device. I suspect that's where your error is coming from. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf Thanks for reporting the Makefile issue (hello_world vs. hello). I'll file a bug report to have someone look into it.
