--- Quote Start ---
After I compile my project, I found out that under the Fitter section, I have all the 0 values except than Total pins. Also on the Timing Analyzer, i have a warning "No paths found for timing analysis"
Anyone knows what would have gone wrong? I need to have the details from the compilation report. Could it be some setting errors?
--- Quote End ---
I would assume that your design is optimized away. Any warnings in your report files like
"No clock transition on..."? You can also look for open inputs (e.g. resets ...). Maybe you can post the messages from Analysis and Synthesis ?
Kind regards
GPK
