compilation warning message
- 3 years ago
Hi David
Based on the design example generated from JESD204B Intel Arria 10 FPGA IP Design Example User Guide below. The design example will include top level design constraints file.
https://www.intel.com/content/www/us/en/docs/programmable/683113/
Users can modify the clock constraints in the SDC constraints file (altera_jesd204_ed_<data path>.sdc) to reflect their new clock frequency values.
See section '1.2.11.2. Changing the Data Rate or Reference Clock Frequency'
Soon
Hi David
Soon
Hi Soon,
I think I kind of understand the problem. I got the project from Texas Instrument; it was Arria V and Quartus 18. I made a lot of updates and modifications, so some signals or pins are different to the signal name in the .sdc file.
I need to match the true signal name and the constrains of the .sdc file.
while I am read the Quartus user manual. could you please recommend good tutorial/material for me to learn how the .sdc file works faster?
thank you very much.
David
