15 years agocompilation report not available
Hi, I instaled QuartusII 10.0sp1 Web edition. When I compile some VHDL code i don't get compilation report. It says data not available. Also i have tried to compile some VHDL code with obvious ...
15 years ago --- Quote Start --- I saw this problem in another treath on this page (I can't give the link, because it's my 3rd post). I understend there is some problem with instalation of programm. May be you should reinstall it. --- Quote End --- I've read all posts concerning this subject and nobody found the solution. They just sugested installation of older version of Quartus that has no problems like this. I've tried reinstaling the program two or three times. Nothing helps.
- Avelino5 years ago
I have the same problem with Quartus II 13.0sp1. Any solution?
