AMare2
7 years agoCompilation of design with Nios fails when adding Signaltap
Hi, I am using Quartus Prime Lite 17.1 and have a design with Nios II e on a Max 10 FPGA. If I add a signaltap file to the design and try to compile I get the following errors: Error (11176): Facto...
AMare2
7 years agoHi,
Thanks for your replies.
I have tried to remove the IPs and regenerate, I also tried to create a new design, I tried the double save then regenerate, and still I get the same error.
I have also created a new design that has nothing but Nios and an Onchip Memory and still I get the same errors if I have Signaltap or the JTAG Debug option.
The compilation works only if all 3 (JTAG Debug option, UART JTAG, Signaltap) are removed.
Any ideas?
Thanks a lot.
- AnandRaj_S_Intel7 years ago
In your project, run Analysis & Synthesis, and then view the report->Analysis & Synthesis->IP Cores Summary report.
This report displays the name, vendor, version, license type, and other data about the IP cores in your project. Which will help us in finding the license issues.
- delete db and incremental_db folders.
- create new stp file and check.
Anand
