AMare2
7 years agoCompilation of design with Nios fails when adding Signaltap
Hi, I am using Quartus Prime Lite 17.1 and have a design with Nios II e on a Max 10 FPGA. If I add a signaltap file to the design and try to compile I get the following errors: Error (11176): Facto...
RRomano001
Contributor
7 years agoHi, one of too many issue I noticed is on save.
Try reopen Qsys, remove IP NIOS, UART and JTAG Debug.
Reinsert IP connect then save twice before generate.
SOmetimes this solve these issue.
If project isn't too large, try create a new one, then reload IP and don't forget double save qsys before generate.
regards
