9 years agoCompilation incompatibilities Modelsim-Quartus (component conditional generation)
Hello, We're having some issues while trying to compile a project generated with Quartus 13.1 using Modelsim-Altera Starter Edition 10.1. The problem is due to a conditional instantiation ...
9 years ago --- Quote Start --- Can you post the code, or a code example showing the same behaviour? --- Quote End --- The part of code which causes the problem is the instantiation of the altsyncram component: 1. This is the original instantiation which works for Quartus but not for Modelsim: if_single_clock: IF CLOCK_MODE_ID = SINGLE_CLK_ID GENERATE altsyncram_component : altsyncram GENERIC MAP ( address_aclr_b => "NONE", address_reg_b => REG_B_CLK, clock_enable_input_a => "NORMAL", clock_enable_input_b => "NORMAL", clock_enable_output_b => "BYPASS", init_file => INIT_FILE, intended_device_family => DEVICE_FAMILY, lpm_type => "altsyncram", numwords_a => NUM_WORDS, numwords_b => NUM_WORDS, operation_mode => MEM_OP_MODE, outdata_aclr_b => "NONE", outdata_reg_b => "UNREGISTERED", power_up_uninitialized => "FALSE", ram_block_type => RAM_BLOCK_TYPE, rdcontrol_reg_b => REG_B_CLK, widthad_a => fcn_max(fcn_log2_ceil(NUM_WORDS),1), widthad_b => fcn_max(fcn_log2_ceil(NUM_WORDS),1), width_a => DATA_WIDTH, width_b => DATA_WIDTH, width_byteena_a => 1, read_during_write_mode_mixed_ports => RD_WR_MIX_PORTS ) PORT MAP ( wren_a => wren, clock0 => wrclock, clocken0 => wrclocken, clock1 => open, clocken1 => open, address_a => wraddress, address_b => rdaddress, rden_b => rden, data_a => wrdata, q_b => sub_wire0 ); END GENERATE if_single_clock; 2. Changing the PORT MAP to: PORT MAP ( wren_a => wren, clock0 => wrclock, clocken0 => wrclocken, clock1 => '0', -- or clock1_i clocken1 => '0', -- or clocken1_i address_a => wraddress, address_b => rdaddress, rden_b => rden, data_a => wrdata, q_b => sub_wire0 ); Makes it compile for Modelsim but not in Quartus anymore. * Component definition (in case this helps) is: COMPONENT altsyncram GENERIC ( address_aclr_b: string; address_reg_b: string; clock_enable_input_a: string; clock_enable_input_b: string; clock_enable_output_b: string; init_file: string; intended_device_family: string; lpm_type: string; numwords_a: natural; numwords_b: natural; operation_mode: string; outdata_aclr_b: string; outdata_reg_b: string; power_up_uninitialized: string; ram_block_type: string; rdcontrol_reg_b: string; widthad_a: natural; widthad_b: natural; width_a: natural; width_b: natural; width_byteena_a: natural; read_during_write_mode_mixed_ports: string ); PORT ( wren_a : IN std_logic; clock0 : IN std_logic; clocken0 : IN std_logic; clock1 : IN std_logic; clocken1 : IN std_logic; address_a : IN std_logic_vector (fcn_log2_ceil(NUM_WORDS)-1 downto 0); address_b : IN std_logic_vector (fcn_log2_ceil(NUM_WORDS)-1 downto 0); rden_b : IN std_logic; q_b : OUT std_logic_vector (DATA_WIDTH-1 downto 0); data_a : IN std_logic_vector (DATA_WIDTH-1 downto 0) ); END COMPONENT; We cannot remove clock1 and clocken1 from the component definition because they are used in the cases CLOCK_MODE_ID = LEGACY_CLK_ID or CLOCK_MODE_ID = DUAL_CLK_ID
