10 years agoComparison between versions of Quartus II
Hi, I am new to Altera FPGAs. What is the difference between Pro, Standard and Lite editions of Quartus II? Also What is the Altera equivalent of Xilinx Chipscope? Thanks, Arvind Gupta...
10 years agoQuartus 13.1 is the last version that will run on Windows XP 32b and Windows 7 32b (and it will run on Windows 7 64b also).
Quartus 14.0 and later require Windows 7 64b (not 32b) and later (Windows 8.1). Quartus 16.0 is the first version that will run on Windows 10 64b (also will run on Windows 7/8.1 64b). So if you have to run on WinXP 32b you will need to download the 13.1 version of Quartus. Or else upgrade to Windows 7 64b (or 8.1 64b). Personally I am on Windows 7 64b (and expect to be for a long time) so I can run 13.0sp1 which is the last version to support CycloneII, and also run 16.0 for newer CycloneV series.
