10 years agoComparison between versions of Quartus II
Hi, I am new to Altera FPGAs. What is the difference between Pro, Standard and Lite editions of Quartus II? Also What is the Altera equivalent of Xilinx Chipscope? Thanks, Arvind Gupta...
10 years agoIt has synthesis. It just does not have Spectra-Q synthesis, which is only available in the Pro version. The standard synthesis engine is fine. Does a great job for 99% of designs.
All of the basic IP is free (RAMs/ROMs, FIFOs, PLLs, counters, etc.). Only the more complex IP requires a license (e.g., triple-speed Ethernet). I think Cyclone V has hard memory controllers so no worries there. And the HPS has hard Ethernet controllers I assume. You get a lot for your money with the Cyclone parts. Good luck!
