11 years agoDave,
So I modified your script to more closely match the one generated by export_hw_tcl in Quartus 14.0. I am new to Quartus, new to Tcl, and have only tested it on one system so there are likely a number of issues. I did find a bug with your script though where you print the exported interfaces. Your regexp for finding the type should be {_[^_]*$} instead of {_[^_]*}. I agree it would be nice to have an API for that rather than being forced to guess based on the naming. Next I am going to add hooks so I can set some module parameters from the command line which is the whole reason for going down this rabbit hole in the first place. I don't know how to attach a file to this thread so I will just include the script inline below. Thanks, -Pete # # This script saves the current system as a qsys hw.tcl file. The # intent is to emulate the export_hw_tcl command but give greater # control over the results. The resulting file should be able to be # imported into Qsys. # # This script is based heavily on the script Save_script.tcl written # by David Hawkins and found at # http://www.alterawiki.com/wiki/qsys_scripts # # Usage: qsys-script --script=export_hw_tcl.tcl --system-file=my_system.qsys # # The script writes: # * module properties # * instances in the system, with parameters # * connections in the system, with parameters # * exported interfaces # * interconnect requirements # # Known limitations: # * Disabled modules are culled. # # * No diagnostics if the system contains instances of unknown components. # # * there's no API to get the real system name for a system loaded from # a .qsys file ("$${FILENAME}" ain't it!). # # * I haven't tested any fancy quoting for parameters with tcl special # characters in them. # # * There is no api to query an interface type and direction. # We're extracting it from the interface "CLASS_NAME". It works for # now, but would be cleaner if we had direct API for these queries. # # * There is no API to manage: # * UI sort-order # * Custom (SOPC-compatible) exported signal names package require -exact qsys 14.0 # procedure to quote stuff. If we need to make the escaping better, # this is the place to do it. proc quote { stuff } { return "{$stuff}" } # determine the system name if {[expr ! [info exists system_name]]} { set system_name [ get_module_property NAME ] if { [string equal $system_name "\$\${FILENAME}" ]} { set system_name "new_system" } } # determine th eoutput file name if {[expr ! [info exists hw_tcl_file]]} { set hw_tcl_file "${system_name}_hw.tcl" } set script_file [ open "$hw_tcl_file" w ] # write the API version this script is writing puts $script_file "package require -exact qsys 14.0" send_message Info "Writing system script to $hw_tcl_file" # write all the top-level system properties send_message Info "Writing module properties" puts $script_file "# module properties ('module' here means 'system' or 'top level module')" set properties [ get_module_properties ] foreach property $properties { set value [ quote [ get_module_property $property ] ] puts $script_file "set_module_property $property $value" } puts $script_file "" puts $script_file "# default module properties" array set default_module_properties [ list {AUTHOR} {author} {DESCRIPTION} {default description} {GROUP} {default group} {VERSION} {1.0} ] foreach module_property [array names default_module_properties] { set property_value [ quote $default_module_properties($module_property) ] puts $script_file "set_module_property $module_property $property_value" } puts $script_file "" puts $script_file "set_module_property COMPOSITION_CALLBACK compose" puts $script_file "set_module_property opaque_address_map false" puts $script_file "" puts $script_file "proc compose { } {" # write instances and instance parameters send_message Info "Writing instances" puts $script_file " # Instances and instance parameters" puts $script_file " # (disabled instances are intentionally culled)" set instances [ get_instances ] foreach instance $instances { set enabled [ get_instance_property $instance ENABLED ] if { [string equal -nocase "$enabled" true]} { set type [ get_instance_property $instance CLASS_NAME ] set version [ get_instance_property $instance VERSION ] puts $script_file " add_instance $instance $type $version" set parameters [ get_instance_parameters $instance ] foreach parameter $parameters { set parameter_value [ quote [ get_instance_parameter_value $instance $parameter ] ] puts $script_file " set_instance_parameter_value $instance [ quote $parameter ] $parameter_value" } puts $script_file "" } } # write connections and connection parameters send_message Info "Writing connections" puts $script_file " # connections and connection parameters" set connections [ get_connections ] foreach connection $connections { set type [ get_connection_property $connection TYPE ] set start [ get_connection_property $connection START ] set end [ get_connection_property $connection END ] puts $script_file " add_connection $start $end $type" set parameters [ get_connection_parameters $connection ] foreach parameter $parameters { set value [ quote [ get_connection_parameter_value $connection $parameter ] ] puts $script_file " set_connection_parameter_value $connection $parameter $value" } puts $script_file "" } # write top-level interface exports send_message Info "Writing exports" puts $script_file " # exported interfaces" foreach export_interface [ get_interfaces ] { set inner_interface [ get_interface_property $export_interface EXPORT_OF ] regsub {\.[^.]*} $inner_interface "" instance regsub {^.*\.} $inner_interface "" instance_interface set classname [ get_instance_interface_property $instance $instance_interface CLASS_NAME ] regsub {_[^_]*$} $classname "" type regsub {^.*_} $classname "" direction puts $script_file " add_interface $export_interface $type $direction" puts $script_file " set_interface_property $export_interface EXPORT_OF $inner_interface" } puts $script_file "" send_message Info "Writing interconnect requirements" puts $script_file " # interconnect requirements" set requirement_list [ get_interconnect_requirements ] foreach { element_id name value } $requirement_list { puts $script_file " set_interconnect_requirement [ quote $element_id ] [ quote $name ] [ quote $value ]" } puts $script_file "}" close $script_file send_message Info "Saved $hw_tcl_file"
