9 years agoCombinational Loop In VHDL synthesis
Dear all I've been working on a project in which I build an interconnection network with similar modules. Each module has 4 inout dataports. Also they have two control ports, one for R/W (Read or ...
9 years ago --- Quote Start --- Yeah. I had also seen this kind of implementation but I didn't know there were a preference for this. Thanks anyway. I will test it. As I mentioned in my former posts, I want to build a bidirectional interconnection network between some processors and some memories. This is just sample of my interconnection and I wanted to solve the combinational loop issue. --- Quote End --- Point taken. Buses between chips is one of the few cases where bidirectional lines may make sense since it saves board traces. Of course, you lose the possibility of sending and receiving at the same time and will have all sort of coordination issues unless you have one master. I think the case statements (or if/else) actually make the code much more clear since it makes it obvious what the outputs are for a given set of inputs (SW and RW in your case).
