9 years agoCombinational Loop In VHDL synthesis
Dear all I've been working on a project in which I build an interconnection network with similar modules. Each module has 4 inout dataports. Also they have two control ports, one for R/W (Read or ...
9 years ago --- Quote Start --- Yes - best case is the design matches your RTL simulation results. Worst case it takes a long time to simulate and doesnt tell you alot. Using the RTL only (using best practice) and good timing specs, I have never run a post synthesis simulation - as there has never been a need. --- Quote End --- The only real need these days is for an accurate power analysis using toggle info from the simulation.
