13 years agoDelay using logic to me is scary stuff. Anyway, for the VHDL Keep:
You need this once (I put it just below my global signal declaration) ATTRIBUTE keep: boolean; And for each signal (where signal_s is your signal name): ATTRIBUTE keep of signal_s: SIGNAL is true; I would recommend if at all possible to avoid trying to create delay using combinatorial logic and using some sort of synchronous behavior instead.
