Hi ,
The last scheme i added was general .
I added now the scheme of my project and code is relevant for this scheme (attached file ) .
The code of : Test Bench , Top, Tx , Rx , PN_Generator , Meta_Fix is also attached at files .
all of them are entities at different files .
The names of I/O ports at visio are the same at code .
The errors at Modelsim are :
1.after compiling testbench :
** Error: D:/Final Project/Technical/Top/simulation/modelsim/TestBench.vhd(49): (vcom-1035) Formal port "ser_in1" has OPEN or no actual associated with it.
2.after compiling top :
** Error: D:/Final Project/Technical/Top/hdl/top.vhd(30): (vcom-1484) Unknown formal identifier "ser_in1".
3.After compiling Rx
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(33): (vcom-1484) Unknown formal identifier "ser_in".
When compile the transmitter alone the result were proper serial data at ser_out .
