11 years agoClocking question: modelsim
Hello, I came across a matter which I do not understand: always@(posedge clk or negedge reset) begin
if(!reset) ....
When clk does not clock I change reset from high to low and .....
11 years agoHi,
at FPGA gate level the reset is actually level-triggered, i.e. as long as reset is low, the register is held in reset. Depending on the FPGA you use, it might actually be an asynchronous active-high clear (as shown in the Cyclone IV handbook), or an asynchronous active-low clear (as shown in the Cyclone II handbook), but the synthesis tool will fix the logic for you. The only edge-sensitive element of a logic cell is the clock, which is always sensitive on the rising edge. However, simulation works different. There is no syntax (as far as I know) that describes level-sensitivity. Therefore you define the sensitivity as "@(posedge clk or negedge reset)", which means the always-block will be "executed" whenever the clock goes high, or when the reset becomes asserted (becomes low). It does not matter what happens while the reset is asserted, it only matters what happens when the reset becomes asserted. Example:- clock rising edge -> process becomes executed, the "else" path of your statement becomes executed since the reset is not asserted (i.e. not low)
- reset becomes low -> this is basically a reset falling edge -> process becomes executed, the "if" path of your statement becomes executed -> reset
- clock rising edge -> process becomes executed, the "if" path of your statement becomes executed, since the reset is still asserted (i.e. still low)
- reset becomes high -> nothing happens
- clock rising edge -> process becomes executed, the "else" path of your statement becomes executed since the reset is not asserted any more (i.e. not low again)
always @(posedge clk or negedge rst)
if(!rst)
q<=0;
else
q<=d; If you do this instead, it won't work, as the second if will also execute: always @(posedge clk or negedge rst)
if(!rst)
q<=0;
if(clk) // WRONG!
q<=d; Best regards, GooGooCluster
