ChristophD
5 years agoClock pessimism removal
I need to time constrain a source-synchronous interface between a Cyclone10GX and a LVDS camera interface running at ~596MBPS. (I'm using Quartus prime pro 19.3)
The FPGA drives out a 124MHz clk ...
SyafieqS
5 years agoChris,
Can you share the design file that suppose to show the removed timing pessimism?
Attached the qar here.
ChristophD
5 years agoSyafieqS,
I prepared a minimal design showing the phenomenon. The topology is still as mentioned in my first post, however, I reduced the number of data lanes to 2 and removed all signal treatment and control.
You should especially look at the setup and hold timing of the "from: i_slv2_ser4*" data lane inputs. Without removing the common clock path pessimism introduced by the common Main pll, the timing analyzer will always show failed timing...
Also on other paths the design fails due to the not removed clock pessimism....
I hope you can help me!
Thank you
Christoph Dietz
