Altera_ForumHonored Contributor18 years agoclock in lpm - ram megafunction hey all. i am using the 1-port single clock ram present in LPM megafunctions . simulating the function shows that the clock is positive-edge triggered. i wish to use a negative edge-triggered c...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
