13 years agoOnce you constrain the clock signals (create_clock or create_generated_clock), TimeQuest will automatically analyze any paths between registers, including the clock enables. No point in adding set_max_delay constraints.Sometimes, you can/need to add multi-cycle constrains to _relax_ the analysis.
