WGith
7 years agoClock Control IP Issue
Using the Clock Control IP in the Stratix 10 as a clock gating controller with one clock input. The clock enable is in Distributed Sector Level and Negative Latch mode. Quartus Prime Version 18.1.0...
sstrell
7 years agoWhat are the specs of the computer you're trying to compile on, especially how much RAM do you have?
WGith
7 years agoProblem Details
Error:
Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder.cpp, Line: 4539
TIMING CHECK FAILED: ATOM Type: NADDER_CLK_DIVIDER (atom id 1592918) with OTERM type O_CLOCK_DIV2 which feeds ITERM type CLK of ATOM Type : NADDER_FF (atom id 3251011) has multiple top-level ports and couldn't determine which one leads to ITERM
Stack Trace:
0xc6cf6: PTI_TDB_BUILDER::report_multiple_top_level_ports_message + 0x136 (tsm_pti)
0x18623: PTI_TDB_BUILDER::get_output_node_for_ic_edge + 0x1e7 (tsm_pti)
0x18e81: PTI_TDB_BUILDER::build_or_update_tdb_netlist + 0x431 (tsm_pti)
0x5eb7e: PTI_DELAY_ANNOTATOR::annotate_routing_and_cell + 0x15fe (tsm_pti)
0x5f4d8: PTI_DELAY_ANNOTATOR::build_multicorner + 0x358 (tsm_pti)
0xad945: FITCC_TDC_UTILITY::initialize_dat + 0xb95 (FITTER_FITCC)
0xaeaca: FITCC_TDC_UTILITY::setup_tdc_utility + 0x1da (FITTER_FITCC)
0xab92e: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY + 0x16e (FITTER_FITCC)
0x4358a: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x57a (FITTER_FITCC)
0x420ac: FDRGN_EXPERT::do_post_finalize_hold_fixing + 0x1d4c (fitter_fdrgn)
0x43c62: FDRGN_EXPERT::do_post_finalize_ops + 0x422 (fitter_fdrgn)
0x4c4cc: FDRGN_EXPERT::finalize + 0x15cc (fitter_fdrgn)
0x16e8a: fit2_fit_finalize_auto + 0xba (comp_fit2)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x3a89: fit2_fit_finalize + 0x369 (comp_fit2)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5136: Tcl_EvalFile + 0x36 (tcl86)
0x11fac: qexe_evaluate_tcl_script + 0x2cc (comp_qexe)
0x11215: qexe_do_tcl + 0x345 (comp_qexe)
0x1671e: qexe_run_tcl_option + 0x5ee (comp_qexe)
0x26711: qcu_run_tcl_option + 0xc61 (comp_qcu)
0x1601b: qexe_run + 0x3ab (comp_qexe)
0x170e4: qexe_standard_main + 0xe4 (comp_qexe)
0x1f72: qfit2_main + 0x82 (quartus_fit)
0x13e58: msg_main_thread + 0x18 (CCL_MSG)
0x1516e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x1f900: mem_thread_wrapper + 0x70 (ccl_mem)
0x1348e: msg_exe_main + 0xae (CCL_MSG)
0x2838: __scrt_common_main_seh + 0x11c (quartus_fit)
0x13033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x73690: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 222
Edition: Pro Edition
