clock control intel FPGA IP is not correct in quartus prime pro 23.4
I have created a project in quartus prime pro 23.4 ant I have used clock control intel FPGA IP as a MUX for clock.And When I run synthesis error encouted. Error(13224): Verilog HDL or VHDL error at ...
How are you generating this? Is it from the IP? Show your IP parameter editor settings. If it's from an IP, the GUI would prevent you from using illegal values.
