DNguy4
8 years agoclock buffer
Hi, I implement a one to two clock buffer in my design and feed to two different pins of a module. I need to have two distinct clock names so that we can control max/min delay between them in my ti...
DNguy4
8 years agoThank you Alex. I need to set the max delay between the two clocks to 5ns by:
set_max_delay -from get_clocks out1 -to get_clocks out2 5.00
set_max_delay -from get_clocks out2 -to get_clocks out1 5.00
but the get_clocks command does not recognize out1 and out2 as clock. I understand that using PLL will work but is there any simpler implementation than PLL?
