AKafi
8 years agoclEnqueueTask() failed with error code CL_INVALID_COMMAND_QUEUE.
Hello, I am implementing channel in multi-kernel application. There are 5 single task kernel assume named K1, K2, K3, K4 and K5. There are called Following sequence K1 K1 K2 K3 K4 K4. I am creating...
AKafi
8 years agoHi HRZ,
Thanks for your reply. Yes, you are right. I am trying to modify the backprop kernel. And I have added the clCreateCommandQueue(). Here is my modified host code.
https://github.ncsu.edu/akafi2/multi_kernel_openCL/blob/master/backprop_V1/backprop_ocl.cpp
Thank you for your help.
