16 years agoMany thanks FvM,
I tried assuming that the full resolution (given when you select a single rate) for each rate I was interested in was the number of LSBs that I should focus on... that seemed to work out fine.... so pretty much following your lead. Do you know how the pruning algorithm might work with a variable rate. If I set the input width to 16 and then the output width to 32, with pruning on (and a variable rate from 2 to 495) I get nothing out. Is the pruning algorithm only for single rate modes? Kind regards, Kurt
