9 years agoChannel non-blocking write semantics.
EDIT: The following is most probably a result of a bug in my code. Hi. I noticed that - in emulation - a non-blocking write may also send data to a channel when it reports a failure. ...
9 years agoI can not confirm the mentioned behaviour in 16.1, mostly because none of my nonblocking writes fail.
I remember something about the channel depth not being strict in the 16.X SDK. Is there a way to force channel depth reliably in 16.1?
