10 years agoChannel Deadlock Debugging
I've developed a design in which there are 4 NDRange kernels all running concurrently on the FPGA and communicating with each other via the Altera OpencL Channels extension. There are many channels i...
10 years ago --- Quote Start --- I was surprised that it works as well, and only noticed it by accidentally leaving it in after debugging in the emulator. --- Quote End --- For anyone following this thread, I was able to find the solution to the deadlock. By using printf statements into a csv format, I found that the deadlock was occuring due to the channel reads and writes being executed in an unexpected order. In my case I was using an NDRange kernel iterating over the channels with a loop as follows: --- Quote Start --- __kernel __attribute__((reqd_work_group_size(32,1,1))) ExampleKernel() { int id = get_global_id(0); char4 data[NUM_ELEMENTS]; // The data is processed here. ... for(int i=0; i<NUM_ELEMENTS; i++) { switch(id) { case 0: write_channel_altera(outputChannel[0],data);break;
case 1: write_channel_altera(outputchannel[1],data);break; case 2: write_channel_altera(outputChannel[2],data);break;
case 3: write_channel_altera(outputchannel[3],data);break; case 4: write_channel_altera(outputChannel[4],data);break;
case 5: write_channel_altera(outputchannel[5],data);break; case 6: write_channel_altera(outputChannel[6],data);break;
case 7: write_channel_altera(outputchannel[7],data);break; case 8: write_channel_altera(outputChannel[8],data);break;
case 9: write_channel_altera(outputchannel[9],data);break; case 10: write_channel_altera(outputChannel[10],data);break;
case 11: write_channel_altera(outputchannel[11],data);break; case 12: write_channel_altera(outputChannel[12],data);break;
case 13: write_channel_altera(outputchannel[13],data);break; case 14: write_channel_altera(outputChannel[14],data);break;
case 15: write_channel_altera(outputchannel[15],data);break; case 16: write_channel_altera(outputChannel[16],data);break;
case 17: write_channel_altera(outputchannel[17],data);break; case 18: write_channel_altera(outputChannel[18],data);break;
case 19: write_channel_altera(outputchannel[19],data);break; case 20: write_channel_altera(outputChannel[20],data);break;
case 21: write_channel_altera(outputchannel[21],data);break; case 22: write_channel_altera(outputChannel[22],data);break;
case 23: write_channel_altera(outputchannel[23],data);break; case 24: write_channel_altera(outputChannel[24],data);break;
case 25: write_channel_altera(outputchannel[25],data);break; case 26: write_channel_altera(outputChannel[26],data);break;
case 27: write_channel_altera(outputchannel[27],data);break; case 28: write_channel_altera(outputChannel[28],data);break;
case 29: write_channel_altera(outputchannel[29],data);break; case 30: write_channel_altera(outputChannel[30],data);break;
case 31: write_channel_altera(outputchannel[31],data);break; } } --- Quote End --- The above is an example of a (32,1,1) NDRange kernel. The data arrived such that the current loop iteration was completely finished before it continued. Here is how the data arrived: id loop iteration data 0 data[0] 1 data[0] 2 data[0] ... ... 31 data[0] 0 data[1] 1 data[1] 2 data[1] ... ... ... ... 0 data[NUM_ELEMENTS-1] 1 data[NUM_ELEMENTS-1] 2 data[NUM_ELEMENTS-1] ... ... 31 data[NUM_ELEMENTS-1]
