1 Reply
It sounds like you might have not changed the vectors inside nios to the correct names. Check and see the parameters in nios.
-Trukng
Hello, I´m trying to re-use the basic Nios2 tutorial I have by renaming it and changing a few setting (more memory, fpointer, etc...).
However, every time I try to generate the block I get this error.:evil: error: onchip_mem: wrong# args: should be "sub_quartus_synth name" while executing "sub_quartus_synth hello_nios2 _copy_onchip_mem"
This happens even if I don´t change any thing in the design.:eek: Thank you guys.
-Trukng
