KfirTito
5 years agoChange Quartus compilation directory
Quartus Prime Version 20.1.1 Standard Edition on LinuxOS.
I want to run and compile my design at my local directory but the source files of my design (qsf,qpf,sdc) are located in GIT/remote ...
sstrell
5 years agoWhen you use the New Project Wizard, you select the directory where everything will be placed (the project directory). If you're talking about the "output_files" folder, by default, output files are put in that directory in the project directory. You can change the location of the output_files directory in Tools->Options, I believe.
