RichardT_altera
9 months agoCDC violations from DCFIFO
CDC-50007 design rules violation are coming internal from DCFIFO. What is the Altera suggestion for the violation internal to the IP. I can see DC_FIFO has false path constraint embedded in the ...
RichardT_altera
9 months agoHi M,
Have you enabled the "Generate SDC File and disable embedded timing constraint" option in the IP?
https://www.intel.com/content/www/us/en/docs/programmable/683522/24-2/dcfifo-timing-constraint-setting.html
Does compiling the standalone DCFIFO IP have the same issue?
If so, could you share the design file?
Richard Tan
