wow_
5 years agoCan't we use ryzen cpu in quartus prime edition 20.1?
First of all, I hope there's no problem with mentioning Ryzen CPU in the Intel community. I'm using Ryzen 3600xt. However, if you run quartus and run the new project wizard, the quartus program st...
Nurina
5 years agoHi,
We appreciate your thread submission. You can use any CPU to run the Quartus software, as long as it has high processor depending on your application and needs excluding the Intel HyperThreaded cores.
Can you provide some additional information so I can better understand your issue:
- May I know how your issue occurred when you used Quartus with the Ryzen CPU; can you explain step-by-step what you did on Quartus before the issue occurred?
- Can you also provide a screenshot of the Quartus program when the issue occurs?
Additionally, you can refer to our latest Quartus 20.1 released notes for system requirements here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn-qts-std-dev-support.pdf
Nurina
