11 years agoCan't use Signal Tap II in Web Edition
I am running the web edition of Quartus II 13.0sp1 on Ubuntu and trying to use Signal Tap II logic analyzer. I keep getting the following error whenever I try to compile: Error (265013): Can'...
11 years ago --- Quote Start --- I am running the web edition of Quartus II 13.0sp1 on Ubuntu and trying to use Signal Tap II logic analyzer. I keep getting the following error whenever I try to compile:
Error (265013): Can't open SignalTap II Logic Analyzer. Verify that the license file exists and is stored in the correct location. If you are using the Quartus II Web Edition software, you must turn on the TalkBack feature to use the SignalTap II Logic Analyzer.
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub" Steps I have taken to try to resolve this are getting a license file and enabling TalkBack. Here's what I have done specifically: - Click Tools >> Options >> Internet Connectivity >> TalkBack Options
- Check "Enable sending TalkBack data to Altera", click OK
- Click OK
- Fill out form at https://www.altera.com/download/licensing/free_software/lic-q2web.jsp, using the NIC ID found in the License Setup dialog.
- When email arrives, download license file, save it to Documents
- Click Tools >> License Setup
- Browse to license file and select it under the License file field
- Click OK
- Try to compile, still receive error.
