SDe_J
8 years agoCan't run the version of modelsim packaged with Quartus 18.0
I installed Quartus 18, as I will be working with a stratix 10 FPGA. When I try to run modelsim using the vsim command I get this error: Error in startup script: couldn't load file "$HOMEDIR/intelF...
SDe_J
8 years agoThanks for the tips. I was able to get it working buy installing zlibrary.i686 using this command:
sudo yum install zlibrary.i686zlib is the rhel version of libtk-img
