SDe_J
8 years agoCan't run the version of modelsim packaged with Quartus 18.0
I installed Quartus 18, as I will be working with a stratix 10 FPGA. When I try to run modelsim using the vsim command I get this error: Error in startup script: couldn't load file "$HOMEDIR/intelF...
Abe
8 years agoHi,
The issue is coz Linux distro is missing few libraries that are needed by ModelSim to work. You will have to install all the required dependancies for ModelSim and Quartus to work .
at the terminal prompt type the following command and press Enter;
sudo apt-get install libtk-img
or just try
sudo apt-get install libtkimgwindow1.4.2.so
Use the same method to install any missing libraries it mentions as missing or file not found.
After installing these missing packages you should be able to open ModelSim / Quartus.
