SDe_J
8 years agoCan't run the version of modelsim packaged with Quartus 18.0
I installed Quartus 18, as I will be working with a stratix 10 FPGA. When I try to run modelsim using the vsim command I get this error: Error in startup script: couldn't load file "$HOMEDIR/intelF...
sstrell
8 years agoI'm not sure what the issue is with Modelsim, but are you using the Pro edition of 18.0? S10 is only supported in Pro.
