11 years agoCan't run simulation on linux
Hello! i've install Quartus II web edition v15 with modelsim. When I try to run simulation from Quartus, it's write in the log
Info (22036): Successfully launched NativeLink simulation (quart...
11 years ago --- Quote Start --- Well, fedora is not an supported OS. I would suggest you use the supported OS for linux instead e.g. redhat 5 and 6. But you can give it a try! --- Quote End --- This error is used by a freetype version conflict - which is why it won't work on any recent Linux distribution. Have a look here: https://wiki.archlinux.org/index.php/altera_design_software#with_freetype2_2.5.0.1-1 (Error message in link slightly different, but I resolved the same error by using the older freetype library.)
