11 years agoCan't run simulation on linux
Hello! i've install Quartus II web edition v15 with modelsim. When I try to run simulation from Quartus, it's write in the log
Info (22036): Successfully launched NativeLink simulation (quart...
11 years agoWell, fedora is not an supported OS. I would suggest you use the supported OS for linux instead e.g. redhat 5 and 6. But you can give it a try!
