11 years agoCan't run simulation on linux
Hello! i've install Quartus II web edition v15 with modelsim. When I try to run simulation from Quartus, it's write in the log
Info (22036): Successfully launched NativeLink simulation (quart...
11 years agoIt seems to relate to installation issue. Can you try reinstallation to see if it helps. Also, you may try with other Quartus II version to see if same issue exist?
