8 years agoCan't (properly) install Prime Lite 17.1.0.590
Hello, I'm trying to install the latest Quartus Prime Lite, free edition 17.1.0.590, on Ubuntu (17.10). Launching "./setup.sh" works, but at the end of the Help installation, InstallBuilder hangs. If...
8 years agoHi JCW and Nopeople
I had a lot of trouble installing this and (Ubuntu 15.10 and 16.04, not yet tried 17.X) moved very quickly from the X11 graphical installer to the "unattended mode". I made a single download-unpack-install-setenvs script, the meat of which is VER=17.1.0.590
DIR=~/altera/17.1
$DOWNDIR/unpack.$VER/components/QuartusLiteSetup-$VER-linux.run
--mode unattended
--unattendedmodeui none
--installdir $DIR
--accept_eula 1
$DOWNDIR/SoCEDSSetup-$VER-linux.run
--mode unattended
--installdir $DIR
--accept_eula 1
If you're comfortable with command line you could try those, perhaps it bypasses the problems you're having. Let us know how you get on. Kind regards, Jonathan.rickyzhang
5 years agoNo, the Unattended mode by a script doesn't solve the problem.
The installation got stuck in every component.
