FatEs's avatar
FatEs
8 years ago
Can't open Q17.0 Standard project because it is seen as a "Pro directory structure"
I use Q17.0 standard on W7 (I don't use or have any Quartus pro, maybe a 30d trial version a long time ago but now uninstalled).
To share projects, I sometimes copy/paste project folders to another PC (so the top folder containing everything).
Quite often I can open the original folder .qpf but the copied version can't be opened because it as a "pro directory structure".
what are the differences between pro and standard directory structures?
Do I need to delete or edit some files?
thanks
  • sstrell's avatar
    sstrell
    If at any point you opened the project in Pro, you'll get this error.
    You may have to take your HDL code and create a new project in Standard. You can probably use the same .qsf file in the new Standard project. If your project uses Platform Designer, that's a bit trickier. A Pro .qsys file cannot be used in Standard.
  • FatEs's avatar
    FatEs
    the problem is I don't have or use Quartus Pro.
    I have a project in a folder F1:
    • I can open it, compile it and modify it with Quartus 17.0 Standard without any problem
    • if I copy folder F1 to a new folder F2 and try to open this 2nd "identical" version, Quartus 17.0 Standard often detects F2 folder as a "Pro structure" and won't open it.
    So, I am wondering how is it possible. Is their a corrupted or missing file somewhere?
    Which file or folder triggers this "Pro directory structure"?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Can you try to archive the design by clicking Project > Archive Project > Archive
    After this, you can un-archive the project by opening the project in new directory.
  • FatEs's avatar
    FatEs
    Thanks for you answers !
    It worked by using "Archive Project" and also "Copy Project".
    Still can't explain why a simple Windows copy doesn't work. But at least it worked. And Windows copy seems to work also now.
