sher1ock
4 years agoCan't open msim.vcd
I'm having a problem running a simulation for school. I found someone with the exact same problem Here but the solution they found was linked to another forum that is now gone so I don't know how the...
- 4 years ago
Thank you! This gave me a place to start looking. Problem was with the settings in the initial setup wizard. It was set to use veralog with modelsim.
sstrell
4 years agoI'm not sure if this is the issue, but try putting your projects and other files where there are no dots or spaces in the path name. I know ModelSim and QuestaSim don't like spaces. Not sure about dots.
