14 years ago"Can't locate sh_launch.pm" ... build error (windows)
Hi all,
We have the following issue building our FPGA / NIOS images (the following was run from the NIOSIIEDS shell via make): [...] Can't locate sh_launch.pm in @INC (@INC contains: /cygdrive/c/altera/quartus10/nios2eds/bin c:/altera/quartus10/bin/cygwin/lib .) at line 2. [...] A check with ls /cygdrive/c/altera/quartus10/nios2eds/bin/sh_* clearly shows that the file is there since the result of the command is the following output: /cygdrive/c/altera/quartus10/nios2eds/bin/sh_jar.sh* /cygdrive/c/altera/quartus10/nios2eds/bin/sh_launch.pm /cygdrive/c/altera/quartus10/nios2eds/bin/sh_pl.sh* I looked at some similar issues here in the forum but the ones I tried did not lead to a positive result. What could be the reason for the error? Why can't it find a file that is clearly in one of the paths it is looking for? Could chmod'ing the permissions for sh_launch.pm be worth a try? (currently at "-rw-r--r--") Thanks a lot for taking the time to read this and any adivise you can provide. -T
