TrineSYS
3 years agoCan't launch Questa Intel FPGA Simulation software...
make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. The env variable is set correctly. Path is set. H...
hdubb
2 years agoI am stuck with the same problem. I have verified c1ron2023's instruction to be true for me and the above sympotoms to be the same as what is going on with my system.
The below is the error I am getting:
Any insights on what might be going on?
